Hello. I’m working with RDK X5 V1.0, SDK V1.1.2, and integrating the Sony IMX296 in 1456×1088 mode, RAW10, 60 fps, 1 lane, 1188 Mbps, I2C bus 6 / 0x1a, MIPI RX0 / PHY0. At the low level, everything works: IMX296 is detected, sensor_start is successful, MIPI HS reception is successful, SIF/VIN consistently receive RAW10 frames at 1456×1088, and srcampy.Camera() now successfully opens the camera and returns NV12 1456×1088 after adding IMX296 to hobot-spdev and fixing VSE. The only remaining issue is at the ISP → NV12/color stage: the image has incorrect color reproduction, for example, B≈255, G≈125, R≈255. At the same time, RAW10 contains the actual scene and changes correctly, meaning the sensor/MIPI/RAW pipeline is working. We also confirmed via dmesg that the ISP loads imx296_tuning.json, but changes to BLS, WB, and CCM.state in the JSON have virtually no effect on the ISP output. Therefore, the main question is: in what specific way should the RDK X5 V1.1.2 ISP8000 be configured and calibrated for the new IMX296 sensor, and which tuning sections should be used?
Despite the fact that IMX296 is not officially supported, we managed to add the sensor to hobot-spdev ourselves. The Camera API now detects IMX296, open_cam() works successfully, and get_img() returns NV12 1456×1088. The only remaining issue is incorrect ISP color reproduction.
I need specific help regarding the ISP8000 calibration workflow: what settings, parameters, or profiles are used for the actual firmware, and how is the correct color output generated for a new Bayer RAW10 sensor?
If the IMX296 already has an external 54 MHz oscillator on the sensor board, is the SoC MCLK from the RDK actually required? Could a “MIPI MCLK not configured” status be considered normal?
