Video Codecs and Encoding Tools on RDK X5
A practical state-of-the-art overview of codecs, encoders, and media tools as they apply to the D-Robotics RDK X5 (Horizon X5 SoC, Ubuntu 22.04, aarch64). The goal is to understand what exists on this board, what each option can do, and the trade-offs so you can choose a pipeline for live streaming, recording, or AI overlays.
For the historical trial-and-error log of one consumer app (Vigibot browser decoder), see video-encoding.md. This guide stays at the platform / toolbox level.
1. What the RDK X5 gives you
| Block | Role on X5 | Typical APIs / libs |
| CSI / ISP / VIO | MIPI camera → NV12 frames (e.g. IMX219) | libspdev / sp_vio, libsrcampy (Python), Hobot camera samples |
| VPU (Wave521) | Hardware H.264 / H.265 encode & decode | hb_mm_mc_* (multimedia), HBN / sample_codec, vendor INI profiles |
| BPU | Neural inference (YOLO, pose, …) | sp_bpu_*, hbDNN*, .hbm models, libpostprocess |
| CPU (8× A55-class) | Software encode, overlays, Node/JS client | libx264, ffmpeg, OpenCV |
| Memory | Contiguous buffers for cam / DNN / codec | hbmem, hbDNN tensors |
IMX219 (CSI)
│ SP / VIO │─────────►│ Overlay │
│ NV12 frames│ │ (OpenCV) │
│ Wave521 VPU │ │ libx264 (SW)│
│ H.264/H.265 │ │ H.264 only │
Pixel format that matters most: NV12 (semi-planar YUV 4:2:0). Almost every efficient X5 path starts or ends there. RGB/BGR is convenient for drawing but costs a conversion before H.264.
2. Concepts that matter on this board
2.1 Codec vs elementary stream vs container
| Term | Meaning | On X5 live paths |
| Codec | Compression algorithm | H.264 most common; HEVC available on VPU |
| Elementary stream | Raw NAL units | Often Annex-B over TCP/UDP (no MP4 wrapper) |
| Container | Muxed file/stream | MP4/TS for recording; live teleop often skips it |
Remux (-c:v copy) never fixes an incompatible bitstream. Only re-encoding changes slice content.
2.2 Profile labels vs slice content (critical on Wave521)
H.264 SPS can claim Baseline (profile_idc=66) while the VPU still emits tools a strict decoder rejects. Patching SPS constraint flags or using ffmpeg bitstream filters does not rewrite slices.
On RDK X5 this showed up clearly with Wave521: offline SPS could be made to look like Constrained Baseline, while a picky browser decoder still showed black/gray. A tolerant player (e.g. VLC) is not a proof of compatibility.
2.3 Latency vs CPU vs compatibility
bitrate efficiency
latency ◄─────┼─────► decoder compatibility
CPU / heat / FPS
On X5 for interactive live video, H.264 + predictable Baseline often beats HEVC/AV1. For local recording or NVR-style use, Wave521 HEVC/H.264 can win on power and resolution.
3. Codecs: what is realistic on RDK X5
| Codec | On X5? | Strengths | Weaknesses | Typical fit |
| MJPEG | Possible (SW / some cams) | Simple, low latency | Huge bitrate | Debug snapshots |
| H.264 / AVC | Yes VPU + SW | Universal clients, mature tooling | Older compression | Live teleop, browsers, robots |
| H.265 / HEVC | Yes mainly VPU | Better compression | Licensing; uneven browser decode | Local storage, RTSP to capable clients |
| VP8 / VP9 / AV1 | SW only if you build it | Open ecosystems | Encode too heavy for real-time A55 at useful res | Rare on this board for live |
Practical default for live + wide client support: H.264.
Practical default for “save CPU / go higher res” on X5: Wave521 if your decoder accepts the bitstream.
H.264 profiles (what you will negotiate)
| Profile | Notes on X5 |
| Baseline / Constrained Baseline | Safest for simple / browser decoders; easiest to get right with libx264 |
| Main / High | Often what HW stacks prefer; better compression if clients are full-featured |
Vendor INI levels (e.g. @L3_1, @L5_2 in HBN samples) |
Tune resolution/bitrate caps; do not guarantee browser-friendly slices |
4. Encoding backends available on RDK X5
4.1 Software: libx264
| How | In-process C/C++ (x264_encoder_*) or ffmpeg -c:v libx264 |
| Input | NV12 (or convert from BGR after overlays) |
| Advantages | Full control of Constrained Baseline, zerolatency, repeat-headers, Annex-B; predictable for strict decoders; works after BPU overlays |
| Disadvantages | Burns CPU (~one core class load at 640×480@15); thermal/FPS ceiling; unused VPU |
| Best when | Client is picky (browser Broadway / WebCodecs Baseline), or you must draw HUD/YOLO/pose then encode |
4.2 Hardware: Wave521 via hb_mm_mc_* / multimedia
| How | Link -lmultimedia -lhbmem …; open encoder session; feed NV12; read bitstream |
| Advantages | Low CPU, higher FPS/resolution headroom, power-efficient |
| Disadvantages | Opaque bitstream; profile/tools constrained by firmware/libspdev; hard to force true Constrained Baseline content; debugging needs NAL dumps |
| Best when | Recording, RTSP to VLC/FFmpeg/NVR, or a decoder known to accept Wave521 output |
4.3 Hardware: HBN / sample_codec (INI-driven)
| How | Vendor multimedia samples under /app/multimedia_samples/…; codec config via .ini (resolution, bitrate, profile tokens) |
| Advantages | Official examples; fast to try HW profiles without writing all glue |
| Disadvantages | Sample-oriented; still Wave521 underneath same compatibility caveats; packaging into a long-running service is extra work |
| Best when | Prototyping HW encode parameters before committing to a custom C++ service |
4.4 Camera → compressed passthrough
Some IP/USB cameras emit H.264 already. On the usual IMX219 CSI path on X5 you get raw NV12, so you still choose SW or HW encode on the SoC.
4.5 Hybrid patterns (all seen or natural on X5)
| Pattern | Pros | Cons | Verdict on X5 |
| Raw NV12 → libx264 | Compatible, controllable | CPU | Go-to for strict live clients |
| Raw NV12 → Wave521 | Efficient | Client may reject stream | Go-to for recording / tolerant clients |
| HW → ffmpeg BSF / SPS patch | Cheap | Does not fix slices | Does not solve Baseline compatibility |
| HW → decode → libx264 | Can fix compatibility | Double cost + latency | Usually worse than raw→x264 |
| NV12 → BPU → draw → libx264 | AI overlays + live | CPU + BPU; CSI exclusive | Standard for YOLO/pose sources |
| ffmpeg subprocess vs in-process x264 | ffmpeg easy to tweak | Extra process / pipes | In-process wins latency/CPU slightly |
5. Frameworks and tools on the board
5.1 FFmpeg
| Use | Role | Caveat on X5 |
-c:v libx264 |
SW encode from raw or files | CPU; good reference bitstream |
-c:v copy + BSF |
Remux / inject extradata | Cannot turn Wave521 into true Baseline |
tcp / udp / rtsp |
Glue for tests | Buffers dominate measured latency |
| Dump / analyze | Validate SPS/NAL offline | Always compare with real client |
Advantage: fastest way to A/B SW vs HW dumps.
Disadvantage: easy to believe a metadata tweak “fixed” profile when it did not.
5.2 GStreamer
| Advantages | Disadvantages |
| Nice for complex graphs if plugins exist | Steeper curve; vendor HW plugins may be missing or custom |
| Good for RTSP server experiments | Harder to debug than a small C++ binary on X5 |
On this platform, SP + libx264 C++ or multimedia sample_codec are often simpler than inventing a full GStreamer Hobot path.
5.3 D-Robotics / Hobot SP stack (libspdev, sp_vio)
| Canonical CSI capture; matches SDK samples | Tied to this SoC; ABI/version sensitive |
| Shared path for cam + BPU buffers | Do not casually rebuild/replace stock camera libs |
Typical capture: sp_open_camera_v2 → sp_vio_get_frame → NV12.
5.4 Python libsrcampy / older scripts
Quick prototypes (Camera.open_cam, get_img) |
GIL + process hops (e.g. pipe to ffmpeg) add overhead |
| Easy to script experiments | For production live encode, C++ in-process is cleaner |
5.5 BPU + postprocess (vision before encode)
| Piece | Role |
.hbm models |
Compiled networks for X5 BPU |
sp_bpu_* / hbDNNInfer |
Run inference (watch NV12 vs NV12_SEPARATE input layouts) |
| OpenCV draw | Boxes / skeletons on BGR or NV12 plane |
| Then encode | Almost always libx264 if the stream must stay Baseline-safe |
Advantage: real-time AI on-device without a PC.
Disadvantage: CSI is typically exclusive (one consumer); wrong tensor layout → silent empty detections.
5.6 Direct libx264 C API (recommended production pattern)
Embed encode in the same process as capture (and optional BPU):
- Grab NV12
- Optional infer + overlay
x264_encoder_encode→ Annex-B- Push bytes to TCP/UDP/file
Advantage vs ffmpeg CLI: no stdin pipe, fewer copies, one binary to systemd-manage.
Disadvantage: you own rate control, IDR, back-pressure, and logging (keep logs on stderr so they never corrupt the bitstream on stdout).
6. Takeaway
On RDK X5, the state of the art is a two-lane toolbox:
- Wave521 (HW) best efficiency when the consumer can decode vendor H.264/HEVC.
- libx264 (SW) best control when you need true Constrained Baseline, mid-stream headers, and AI overlays on NV12.
Everything else (ffmpeg remux, SPS patches, bitstream filters, containers) is useful glue but only re-encoding changes what the decoder must implement. Choose the lane from your decoder, not from the marketing name of the profile.
If anything I explained has to be updated because it was incorrect or a software update added features, please let me know by posting a reply
