1 Problem introduction
When using PTQ model conversion scheme, I do not know where to start in the process of preparing calibration data, and directly give a jpg picture. How to solve the problem that cannot reshape array of size xxx into shape (x, xxx, xxx)?
2 Solution
Taking ResNet18’s pre-processing on imagenet data set as an example, the basic calibration data preparation process is introduced.
2.1 pytorch data preprocessing pseudocode
import torchvision.transforms as transforms
def Data():
image.convert(RGB)
data_transform = transforms.Compose(
image,
[transforms.Resize(224),
transforms.ToTensor(),
transforms.Normalize([0.485, 0.456, 0.406], [0.229, 0.224, 0.225])])
2.2 Prepare Files
[root@7660ab0db525 resnet18]# tree -L 1
├── 03_build.sh
├── origin_image
├── preprocess.py
├── resnet18_baseline_config.yaml
└── resnet18_baseline.onnx
2.3 Image Calibration Data
preprocess.py
import os
src_dir = './origin_image'
dst_dir = './image_converted_rgb_f32' # yaml文件中cal_data_dir参数配置成这个路径即可
pic_ext = '.rgb'
if not os.path.exists(dst_dir):
os.mkdir(dst_dir)
for src_name in sorted(os.listdir(src_dir)):
src_file = os.path.join(src_dir, src_name)
img = cv2.imread(src_file)
img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
img = cv2.resize(np.array(img), (224, 224), interpolation=cv2.INTER_CUBIC)
img = img.transpose(2, 0, 1)
img = img.astype(np.float32)
filename = os.path.basename(src_file)
short_name, ext = os.path.splitext(filename)
pic_name = os.path.join(dst_dir, short_name + pic_ext)
img.tofile(pic_name)
print("write:%s" % pic_name)
** Note ** : In the process of calibration data processing, except for the three operations of normalization, mean reduction and standard deviation, the rest of the parts should be consistent with the data preprocessing during training.
Normalization, mean reduction, and division of standard deviation can be accelerated by inserting preprocessing nodes into the model. How to configure such functions is described in detail in Section 2.4 Model transformation.
Run the preprocess.py script:
[root@7660ab0db525 resnet18]# python3 preprocess.py
write:./image_converted_rgb_f32/ILSVRC2012_val_00000001.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000002.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000003.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000004.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000005.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000006.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000007.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000008.rgb
write:./image_converted_rgb_f32/ILSVRC2012_val_00000009.rgb
Normalization, mean-reduction, and division of standard deviation are integrated into yaml parameter configuration, which is achieved by norm_type, mean_value, and scale_value. The usage of these three parameters in yaml is described in detail in the following examples.
The conversion logic of mean and scale is as follows
data=(input/255−mean)×(1/std)=(input−255mean)×(1/255std)data=(input/255-mean)×(1/std)=(input-255mean)×(1/255std)data=(input/255−mean)×(1/std)=(input−255mean)×(1/255std)
data=(input−meanvalue)×scalevaluedata=(input-meanvalue)×scalevaluedata=(input−meanvalue)×scalevalue
norm_type: 'data_mean_and_scale'
mean_value: 123.68 116.28 103.53
scale_value: 0.017 0.018 0.017
In combination with the calibration data path generated in Section 2.3, configure the yaml file parameters: cal_data_dir: ‘./image_converted_rgb_f32’ and execute the 03_build.sh script to complete the model conversion.
[root@7660ab0db525 resnet18]# sh 03_build.sh
cd $(dirname $0) || exit
config_file="./resnet18_baseline_config.yaml"
model_type="onnx"
# build model
hb_mapper makertbin --config ${config_file} \
--model-type ${model_type}
2022-11-16 10:30:05,057 INFO Start hb_mapper....
2022-11-16 10:30:38,935 INFO Convert to runtime bin file sucessfully!
2022-11-16 10:30:38,935 INFO End Model Convert
