[MicroDuck RL 04] Training: What Happens Behind a Single Command
MicroDuck RL: From Simulation to the Real Robot — Part 04 of 14
With the environment ready, it is time to start training. This part explains every important parameter behind the one-line command.
Start Training
uv run train Mjlab-Velocity-Flat-MicroDuck \
    --env.scene.num-envs 4096 \
    --agent.logger tensorboard
  • --env.scene.num-envs 4096 creates 4,096 parallel simulation environments. This is the key to throughput: every PPO update collects 4,096 × 24 = 98,304 environment steps.
  • --agent.logger tensorboard selects TensorBoard. The default logger is Weights & Biases, which requires an account and sign-in. If you do not use W&B, switch to TensorBoard. Logs are written locally to logs/rsl_rl/velocity/<timestamp>_velocity/ with no loss of functionality.
Important Defaults
Run uv run train <TASK> --help to see every available parameter. The most important defaults are:
Parameter Default Meaning
Physics timestep 0.005 s MuJoCo advances by 5 ms per physics step
Decimation 4 One control action every four physics steps: 0.02 s, or 50 Hz
Episode length 20 s Each environment resets every 20 seconds
--agent.max-iterations 50,000 Maximum number of training iterations
--agent.save-interval 250 Saves a model_*.pt checkpoint every 250 iterations
Learning rate 1e-3, adaptive Adjusted automatically based on KL divergence
Epochs / minibatches 5 / 4 PPO update structure for each batch of experience
What Happens in One Iteration
  1. Each of the 4,096 environments advances 24 steps, with policy inference running in parallel on the GPU.
  2. The system computes rewards, termination conditions, and generalized advantage estimates (GAE) for every step.
  3. PPO updates the policy using 5 epochs and 4 minibatches.
  4. The logger writes TensorBoard data, and a checkpoint is saved every 250 iterations.
Measured Performance on an RTX 5080
Metric Result
Time per iteration Approximately 1.13 s
VRAM usage Approximately 7.3 GB of 16 GB
GPU utilization Approximately 84%
Rule-of-thumb training budget Roughly 1,000 iterations for simple skill tasks; 4,000–6,000 for locomotion tasks, based on the project’s experience notes
Resume from a Checkpoint
uv run train Mjlab-Velocity-Flat-MicroDuck --env.scene.num-envs 4096 \
    --agent.run-name resume \
    --agent.load-checkpoint model_2000.pt \
    --agent.resume True
Run a Smoke Test First
uv run train Mjlab-Velocity-Flat-MicroDuck --env.scene.num-envs 64 --agent.max-iterations 5
According to the project documentation, a smoke test with 64 environments and 5 iterations catches roughly 95% of configuration errors at almost no cost. Always run it before committing to a long training job.
Part 05 moves into the most technical part of the series: a detailed look at the task’s observations, rewards, domain randomization, and curriculum learning.
