[MicroDuck RL 10] How to Read Training Logs
MicroDuck RL: From Simulation to the Real Robot — Part 10 of 14
This installment draws from the repository’s AGENTS.md, a collection of lessons the project team learned through many failed training runs. It is one of the most valuable parts of the series.
Watch Three Things
  1. The mean reward should be increasing.
  2. Episode length should match the task’s expectations. In a walking task, consistently short episodes usually mean the robot keeps falling.
  3. The reward term for the primary objective must actually improve. Total reward can rise entirely because of regularization terms while the desired skill never emerges. This is a common way to fool yourself: the curves look beautiful, but the robot stands still.
Every Penalty Term Must Be Zero or Negative
Episode_Reward/<term> records the weighted value. If a penalty function already returns a negative value and you give it a negative weight, the two signs cancel and create a positive reward. The policy will exploit that loophole aggressively. Whenever you write a configuration, stop and verify the sign convention.
A Zero-Weight Term Will Read Zero
Interpret each metric alongside the curriculum’s weight schedule. A penalty that appears inactive early in training may simply not have been enabled by the curriculum yet.
RL Will Exploit Every Loophole You Leave Open
If you do not define a required pose or constrain how a goal may be reached, the policy will find another way. As a rule of thumb, define critical behaviors with hard state gates—contact state, orientation thresholds, or latches—rather than small penalties. Penalties are soft constraints that a policy can trade off against other rewards. A gate is a hard constraint.
When Training “Fails,” Measure Before You Speculate
Load the checkpoint and run a headless evaluation across different spawn configurations and termination outcomes. Many apparent failures are actually caused by an early checkpoint or an evaluation mismatch, not by a policy that failed to learn.
Inspect Both Video and Metrics
A run can pass every metric and still look obviously wrong on video. Metrics are only projections of what you chose to measure; video shows the behavior itself.
What to Watch in TensorBoard
Panel What to check
Episode_Reward/* Weighted reward terms; verify that the primary objective improves and every penalty remains ≤ 0
Episode_Termination/* Fall rate
Curriculum/* Curriculum progress
Metrics/* Tracking error
The remaining installments are practical references: a command cheat sheet, a beginner’s practice roadmap, a hands-on test log and source map, and an FAQ.
