PTQ Configuration File Explained
Directory
  • 1 Parameter summary
  • 2 Parameter Description
  • 2.1 Model parameter group
  • 2.2 Input parameter group
  • 2.3 Calibration parameter group
  • 2.4 Compiling parameter group
  • 2.5 User-defined Parameter group
  • 3 Performance/precision parameters
  • 3.1 Performance parameters
  • 3.2 Precision parameters
  • 4 Feature parameter
  • 4.1 Fast Performance verification
  • 4.2 Pre-processing normalization
  • 4.3 Resize
  • 4.4 batch model
  • < font color = “blue” size = “4” > 4.5 bandwidth optimization < br > < / font >
  • < font color = “blue” size = “4” > 4.6 reasoning preemption < br > < / font >
  • 4.7 Reacquiring model conversion parameters
When you use the Horizon PTQ toolchain for model transformation, you need to configure a Yaml file with parameters that tell the tool how to parse, calibrate, and compile the model. The Yaml configuration file is described in detail below, based on the J5 OE-v1.1.62 and XJ3 OE-v2.6.2 versions. Please refer to the corresponding section of your current version for the official documentation.
**1 Parameter summary table ** will first through a simple table, organize all the configuration parameters, to help you establish a preliminary understanding, understand their basic role, adaptation platform, and whether it is required;
**2 Parameter Description ** All parameters are introduced one by one to help you understand their usage scenarios and configuration methods.
**3 Parameters related to performance/accuracy ** All parameters related to performance/accuracy will be summarized and sorted out, please ensure that they are correctly configured to avoid wrong evaluation results;
**4 Feature function parameters ** Some of the commonly used functional features are extracted from the corresponding parameters, and the combination is introduced to help you better understand the ability of Horizon PTQ tool chain.
2 Parameter description
  1. ‘prototxt’, ‘caffe_model’, ‘onnx_model’ are used to configure the model file. The caffe1.0 model is configured with only prototxt and caffe_model; Only onnx_model is configured for the ONNX model. For example, ONNX model configuration:
    onnx_model: ***.onnx
    1. ‘march’ is a mandatory parameter that specifies the platform architecture to be deployed for the compiled.bin model. The J5 platform must be configured as bayes and the XJ3 platform must be configured as bernoulli2. For example, the J5 platform model is configured as:
    march: bayes
    3. 'output_model_file_prefix' is an optional parameter used to configure the name prefix of the output model file. The default value is model. For example, if mobilenetv1_224x224_nv12 is configured, all ONNX and bin model files produced by the tool are prefixed with this:
    ```Yaml
    output_model_file_prefix: mobilenetv1_224x224_nv12
    ! [](/api/v1/static/imgData/1693536117734.png)
    4. 'working_dir' is an optional parameter to configure the path where the output is stored. The default value is model_output. If the directory does not currently exist, the tool automatically creates it.
    ```Yaml
    working_dir: 'model_output'
    6. 'output_nodes' is an optional parameter that specifies output nodes for the model. Using the '03_classification/01_mobilenet' classification model as an example, if the following configuration is configured, the two output nodes are added starting from the _original_float.onnx model.
    ```Yaml
    output_nodes: 'conv5_6/sep;  conv6/dw' # Simply configure the node name
    ! [](/api/v1/static/imgData/1693536426683.png)
    7. 'remove_node_type' and 'remove_node_name' are optional parameters without default values. An operator or operators used to connect the head/tail of the model to the input/output is removed from the model. Currently, the node types supported for deletion include Quantize, Dequantize, Cast, Transpose, and Softmax. The Quantize and Dequantize nodes cannot view the node name from the conversion log. You need to use the hb_perf tool (J5 [link] (HTTP: / / https://developer.horizon.cc/api/v1/fileData/horizon_j5_open_explorer_cn_doc/oe_mapper/source/ptq/ptq_tool/hb_perf. html); XJ3  [link] (HTTP: / / https://developer.horizon.cc/api/v1/fileData/horizon_xj3_open_explorer_cn_doc/oe_mapper/source/ptq/ptq_tool/hb_perf .html)) Visual bin model viewing. Two configurations are provided below (** note the node order **), both of which remove the Softmax and Dequantize nodes in the tail of the mobilenetv1 model.
    ```Yaml
    remove_node_type: "Softmax; Dequantize"    # or
    remove_node_name: "prob; fc7_1_HzDequantize"
After the deletion is successful, you can view the following information in the conversion log:
Note that the Quantize and Dequantize nodes are integrated into the model by default using CPU calculations, but it is more efficient to remove them and incorporate them into the post-processing code to avoid redundant data traversal operations.
  1. debug_mode This parameter is optional and has no default value.
    debug_mode: dump_calibration_data
2.2 Enter the information parameter group
This section uses the ‘05_miscellaneous/04_multi_input_example’ multi-input model as an example
  1. ‘input_name’ is used to specify the name of the model input node. When the original model has only one input node, it can not be configured, and the tool will analyze it automatically. This parameter must be configured for multiple inputs, as shown in the following example:
    input_name: image_b; image_g; image_r
    1. ‘input_shape’ is used to specify the data size of the model input node. When the model input is static size, it is optional, and the tool automatically analyzes; If the model input is dynamic size, it must be configured. And if the model has multiple inputs, it should also be in the same order as’ input_name '. In this example, the size is static and can be configured as follows:
    input_shape: 1x1x224x224; 1x1x224x224; 1x1x224x224
  2. ‘input_type_train’ and ‘input_layout_train’ are mandatory parameters, which are used to configure the input data type and arrangement during model training. If the model has multiple inputs, it should also be in the same order as’ input_name '. The preceding example can be configured as follows:
    input_type_train: gray; gray; gray
    input_layout_train: NCHW; NCHW; NCHW
    1. input_type_rt and input_layout_rt are used to configure the type and arrangement of runtime data during.bin model deployment. The former is mandatory, and the latter is optional. If the model has multiple inputs, it should also be in the same order as’ input_name '. The preceding example can be configured as follows:
    input_type_rt: gray;  gray;  gray
    input_layout_rt: NCHW;  NCHW;  NCHW # can also be left unconfigured
    5. input_space_and_range is an optional parameter used to configure the data format for input_type_rt: nv12. If the value is regular, the data range is [0, 255]. If bt601_video is configured, the data range is somewhat compressed and is [16, 235]. The default value of this parameter is regular. This parameter is usually not required.
    ```Yaml
    # input_space_and_range: # Usually not configured
    6. 'input_batch' is optional and the default value is 1. When the model is single input and the first dimension of 'input_shape' is 1, the model can be compiled into batch model using this parameter, which currently supports the configuration range [1-4096]. For example, if you want to compile a single input model of batch4, you can configure the following, ** More information can be found in Section 4.4 of this article **.
    ```Yaml
    input_batch: 4
    Note: The multi-input model does not yet support the configuration of the input_batch parameter, but the multi-input model of batch supports the configuration of the input_shape parameter to describe the batch size.
    ## 2.3 Calibration parameter group
    1. cal_data_dir and cal_data_type are used to specify the path and type of the calibration data store. Among them:
    - If the calibration_type calibration mode is load or skip, neither parameter can be configured.
    - If the calibration data is JPEG original and the following 'preprocess_on' is set to True, then 'cal_data_type' may not be set;
    - If the calibration data is preprocessed and saved as np.tofile (see more: [image data preparation of calibration problem is introduced and processing] (https://developer.horizon.cc/forumDetail/118363912788935513)), cal_data_type tells the tool whether it should be read in float32 or uint8; If not configured, and in non-LOAD /skip calibration mode, the tool will resolve whether the suffix of the storage folder name is **_f32** to determine the data read type. When the cal_data_type configuration conflicts with the suffix name, it has a higher priority.
    - If the model has multiple inputs, the two parameters must be in the same order as' input_name '. The configuration of the multi-input model in the preceding example is as follows:
    ```Yaml
    cal_data_dir: ./calibration_data_b; ./calibration_data_g; ./calibration_data_r
    cal_data_type: uint8; uint8; uint8
  3. preprocess_on Is optional parameter, the default value is False, ** and only applies to the model of 4-dimensional image input **, indicating whether the tool automatically processes the image, including using skimage to read the image, and resize to the size of the input node, the user can choose to use according to the situation, usually False.
    preprocess_on: False
Parameter name
Optional/required
Default value
Support platform
model parameter set
prototxt
Specifies the name of the prototxt file for the Caffe floating point model
< td rowspan = “3” > < font color = “red” > two alternative models
XJ3, J5
caffe_model
Specifies the caffemodel file name for the Caffe floating point model
XJ3, J5
onnx_model
Specifies the ONNX file name for the onnx floating point model
XJ3, J5
march
Specifies the platform architecture that needs to be supported to produce hybrid heterogeneous models
Mandatory
XJ3, J5
Specifies the name prefix
for the hybrid heterogeneous model produced by the transformation
Optional
model
XJ3, J5
working_dir
Specifies where to store the results of the model transformation output
Optional
model_output
XJ3, J5
layer_out_dump
Specifies whether the hybrid heterogeneous model retains the ability to output middle-tier values
Optional
False
XJ3, J5
output_nodes
Specifies the output node of the model
Optional
XJ3, J5
remove_node_type
Set the type of node to be deleted
Optional
XJ3, J5
remove_node_name
Set the name of the node to be deleted
Optional
XJ3, J5
debug_mode
Save calibration data for precision debug analysis
Optional
XJ3, J5
set_node_data_type
Specifies the output of the operator int16, whose functions are integrated into node_info
Optional
J5
node_info
Specifies the operator int16 input/output, or forces the operator to run on the CPU or BPU
Optional
J5
< th colspan = “5” > < font size = “3” color = “blue” > input parameter set < / font >
input_name
Specifies the input node name for the original floating point model
Optional
XJ3, J5
input_type_train
Specifies the input data type of the original floating point model
Mandatory
XJ3, J5
input_layout_train
Specifies the input data layout of the original floating point model
Mandatory
XJ3, J5
input_type_rt
Input data format to be adapted to the converted mixed heterogeneous model
Mandatory
XJ3, J5
input_layout_rt
Input data configuration required for the converted hybrid heterogeneous model
Optional
XJ3, J5
Special format for specifying the input data format
Optional
regular
XJ3, J5
input_shape
Specifies the input data size of the original floating point model
Optional
XJ3, J5
input_batch
Specifies the number of input batches to be adapted to the converted hybrid heterogeneous model
Optional
XJ3, J5
norm_type
Input data preprocessing methods added to the model
Optional
no_preprocess
XJ3, J5
mean_value
Specifies the mean of the image subtracted from the preprocessing method
Optional
XJ3, J5
scale_value
Specifies the numerical scale coefficient of the preprocessing method
Optional
XJ3, J5
Calibration parameter set (All parameters are not independently optional, can not be configured)
cal_data_dir
Specify where to store calibration samples for model calibration
Optional
XJ3, J5
cal_data_type
Specify the data storage type for the calibration data binary
Optional
