RDK X5 Controlling a Servo via Software PWM (C++) with the Horizon WiringPi Fork
Introduction
On the D-Robotics RDK X5, the Ubuntu libwiringpi2 package (Raspberry Pi WiringPi) does not work:
You need to install the WiringPi fork for X5 (Horizon / D-Robotics), then compile a small program that generates 50 Hz pulses with a width of 600–2400 µs (standard hobby servo).
Prerequisites
sudo apt-get update
sudo apt-get install -y git build-essential g++
1. Installing WiringPi (RDK X5 Fork)
sudo git clone https://gitee.com/xin03liu/WiringPi.git /opt/wiringpi-rdk
cd /opt/wiringpi-rdk
sudo git checkout --detach 59cc2e82c7a92d2e4ce5bb8e732ebbfe5512ec3f
sudo ./build
sudo ldconfig
Verification:
ldconfig -p | grep wiringPi
# Expected: libwiringPi.so in /usr/local/lib
ls /usr/local/include/wiringPi.h
Note: gpio readall might fail (undefined symbol: pwmSetFreq) this does not affect our program.
2. Code Example softPWM.cpp
Create the file (e.g., in /app/40pin_samples/ or ~/softPWM.cpp):
// softPWM.cpp — 50 Hz Servo, 600–2400 µs sweep
// Build: see section 3
#include <wiringPi.h>
#include <cerrno>
#include <csignal>
#include <cstdio>
#include <cstdlib>
#include <ctime>
static const int SERVO_HZ = 50;
static const long SERVO_PERIOD_NS = 1000000000L / SERVO_HZ;
static const int PULSE_MIN_US = 600;
static const int PULSE_MAX_US = 2400;
static const int SWEEP_STEP_US = 10;
static volatile sig_atomic_t stopping = 0;
static int g_pin = 29;
static int64_t mono_ns(void)
    struct timespec ts;
    clock_gettime(CLOCK_MONOTONIC, &ts);
    return (int64_t)ts.tv_sec * 1000000000LL + ts.tv_nsec;
static void on_sig(int sig)
    (void)sig;
    stopping = 1;
static void sleep_until(const struct timespec *deadline)
    while (!stopping &&
           clock_nanosleep(CLOCK_MONOTONIC, TIMER_ABSTIME, deadline, NULL) == EINTR) {
static void add_ns(struct timespec *ts, long ns)
    ts->tv_nsec += ns;
    while (ts->tv_nsec >= 1000000000L) {
        ts->tv_sec++;
        ts->tv_nsec -= 1000000000L;
static void emit_servo_pulse(int physical, int pulse_us)
    int64_t width_ns, tend, t;
    if (pulse_us < PULSE_MIN_US) pulse_us = PULSE_MIN_US;
    if (pulse_us > PULSE_MAX_US) pulse_us = PULSE_MAX_US;
    width_ns = (int64_t)pulse_us * 1000LL;
    digitalWrite(physical, HIGH);
    tend = mono_ns() + width_ns;
    do { t = mono_ns(); } while (!stopping && t < tend);
    digitalWrite(physical, LOW);
int main(int argc, char **argv)
    int pin = 29;
    int pulse_us = PULSE_MIN_US;
    int direction = 1;
    struct timespec cycle;
    if (argc >= 2) {
        pin = atoi(argv[1]);
        if (pin <= 0) {
            fprintf(stderr, "Invalid BOARD pin: %s\n", argv[1]);
            return 1;
    g_pin = pin;
    signal(SIGINT, on_sig);
    signal(SIGTERM, on_sig);
    if (wiringPiSetupPhys() == -1) {
        fprintf(stderr,
            "wiringPiSetupPhys() failed.\n"
            "Install the RDK X5 WiringPi fork (section 1), not the standard Pi wiringPi.\n");
        return 1;
    pinMode(pin, OUTPUT);
    digitalWrite(pin, LOW);
    printf("Servo sweep BOARD pin %d: %d-%d us @ %d Hz — Press Ctrl+C to stop\n",
           pin, PULSE_MIN_US, PULSE_MAX_US, SERVO_HZ);
    clock_gettime(CLOCK_MONOTONIC, &cycle);
    while (!stopping) {
        emit_servo_pulse(pin, pulse_us);
        pulse_us += direction * SWEEP_STEP_US;
        if (pulse_us >= PULSE_MAX_US) { pulse_us = PULSE_MAX_US; direction = -1; }
        else if (pulse_us <= PULSE_MIN_US) { pulse_us = PULSE_MIN_US; direction = 1; }
        add_ns(&cycle, SERVO_PERIOD_NS);
        sleep_until(&cycle);
        /* If CPU falls behind: reset to now (prevent pulse bursts) */
        struct timespec now;
        clock_gettime(CLOCK_MONOTONIC, &now);
        if (now.tv_sec > cycle.tv_sec ||
            (now.tv_sec == cycle.tv_sec &&
             now.tv_nsec > cycle.tv_nsec + SERVO_PERIOD_NS)) {
            cycle = now;
    digitalWrite(g_pin, LOW);
    printf("\nStopped — pin %d set to LOW\n", g_pin);
    return 0;
3. Compilation
cd /path/to/softPWM.cpp
g++ -O2 -o softPWM softPWM.cpp \
  -lwiringPi -lrt -lpthread \
  -I/usr/local/include \
  -L/usr/local/lib \
  -Wl,-rpath,/usr/local/lib
4. Running the Program
Connect the servo signal wire to the chosen BOARD pin (e.g. pin 29), with VCC and GND connected to a dedicated power supply (5 V recommended for standard servos with sufficient current).
sudo ./softPWM 29
  • Optional argument: BOARD pin number (default is 29).
  • The servo continuously sweeps from 600 → 2400 → 600 µs.
  • Press Ctrl+C to exit (the pin will be reset to LOW).
Fixed position (no sweep): keep pulse_us constant in the loop, or call emit_servo_pulse(pin, 1500) inside a 50 Hz loop.
5. References
  • Tested WiringPi fork: gitee.com/xin03liu/WiringPi @ 59cc2e82
Very detailed! So impressed!
